Conrad-Johnson Classic preamp
0 Members and 1 Guest are viewing this topic. Read 9235 times.
SteveFord
« on: 31 Dec 2011, 11:41 pm »
Has anybody heard this one?
http://www.conradjohnson.com/It_just_sounds_right/pvclassic.html
If so, is it as good as the reviews say?
I've gotten the new preamp bug for some odd reason and this is certainly priced right.
enginesix
Re: Conrad-Johnson Classic preamp
« Reply #1 on: 22 Feb 2012, 10:17 pm »
it looks like an updated PV10, which I have owned, then traded for a PV12.  the PV10 was ok, and if I had tube rolled I might have kept it.  the PV12 is an excellent pre amp, the phono section is a good match for h/o mc or mm cartridges.  I a few years ago, I got the bug for a new pre amp, an I  bougtht a cary slp-98l.  great pre amp, responds well to tube rolling.  then, a friend gave me a set of telefunken 12AU7's for the linestage of my PV12.  I put the cary away, have not listened to it in 5 years.  the telefunkens with the PV12 have opened my ears.  also, I love conrad johnson equipment.  just my 2 cents.
doug s.
  • makin' music
« Reply #2 on: 23 Feb 2012, 04:29 am »
keep your eyes peeled for a melos - either ma333r or sha-gold/r.  absolutely killer preamps, imo.  i owned a cary slp98 for a coupla months; i put it up f/s the day after i hooked my ma333r into my system.  the cary smoked the melos on looks, if that means anything.   :lol:  it was also better than the rogue 99 magnum it replaced.  the cary was a toss-up between it and the s/s linn kairn i was using before - these two had differing wirtues/wices; the melos combined the strengths of both w/zero weaknesses.
there's a sha-gold on agon right now that i would consider - if you don't want remote or tape loop.  i'd ask quite a bit less than the seller is asking, tho...
doug s.
TONEPUB
« Reply #3 on: 23 Feb 2012, 05:30 am »
It is as good as the reviews say.  I've got a PV-12 that was sent back to CJ that is even better, but I wanted the phono stage.
The Classic is very similar in design and sound to the basic, un - updated PV -12, though a little bit more extended on top and not quite as warm in the midrange as the older PV-12.
if you do need a phono stage (MM), Id seriously consider finding a PV-12 for about $800 and sending it back to CJ for the Teflon cap/power supply upgrade, about $1200.  The result, with some good NOS tubes is shockingly good.  I've got an ACT 2 in my main system and am about to upgrade to a GAT, but the PV-12 is damn good in system two....
I.Greyhound Fan
« Reply #4 on: 23 Feb 2012, 05:32 am »
I would give a listen to the new AVA FET Valve Preamp.  I did a review on it and the new FET Valve amp and DAC over on the Van Alstine circle.  The Preamp is detailed and very musical with excellent bass.
Delta Wave
« Reply #5 on: 23 Feb 2012, 05:36 am »
doug s.
I'm digging my Melos, thanks for the recommendation! ...AND the manual! I'm running it with NOS Phillips (Holland) Miniwatts that were recommended to me for the MA-333r by another person. I'm beginning to figure out the trims for the Pho-tentiometer too.
It is a fantastic preamp but now I've figured out my speakers limits. I'll be in the market for a new set of Maggies in a few months.
Poultrygeist
« Reply #6 on: 24 Feb 2012, 02:23 am »
I liked my CJ PV1/2 but it didn't match as well with my Bottlehead Paramours as the Seduction III does. It's phono stage had lots of gain but I think the Jolida JD9 is better.
