SW 8-16 subwoofers
Danny Richie
Re: SW 8-16 subwoofers
« Reply #20 on: 3 Jan 2012, 08:01 pm »
Danny, I will see if I can get over there sometime next week :) I will take a few pic's.
As for the woofers, I like the sound, (pardon the pun!) of 3 woofers. Do you think there will be any bennefit in using the 3 x 16ohm woofers in a slightly larger box, compared to using 2 x 8 ohm in a smaller box. Do you think I would get decent bass output if i put all 3 units on an open baffle?
You will have more output potential using three of them, but if you use the SW-8-16FR's the box size will be fairly large.
You will also get pretty good bass response form three of them in an open baffle as well.
jparkhur
« Reply #21 on: 3 Jan 2012, 08:09 pm »
Danny,
Do we have any comparisons between the 12 and the 8s as per how many equal a 12 to check what we can do with them.   I know you had not gotten there yet last time i checked.  All things equal...
Jon
PS did you take care of the Plano guy.....flat pack i cc'ed you on
Danny Richie
« Reply #22 on: 3 Jan 2012, 08:16 pm »
I have not had time to make those comparisons yet.
And if it is the guy (name is Guy) that I am thinking of, then I am still working with him.
Ryan45872
« Reply #23 on: 14 May 2012, 03:16 pm »
Danny,
How large of a box are we talking about?
Ryan
Danny Richie
« Reply #24 on: 14 May 2012, 10:10 pm »
Danny,
Ryan
In a sealed box each woofer will need about .7 cubic feet of air space.
