Looking for Strata Mini parts
cjepple
« on: 31 Dec 2011, 01:07 am »
Hi Folks, first post here.
I am in need for a tweeter for one of my Strata Minis (it's blown), and I also believe I need a new crossover or crossover parts. The Mid-woofer of the same speaker also does not produce sound when the speaker is hooked up normally, but if I run speaker cable directly to the driver, it seems to sound fine. That leads me to believe that the driver is OK, but I have a crossover problem.
Does anyone know where I can find a replacement tweeter and cross-over?
Chris
Danny Richie
    • http://www.gr-research.com
Re: Looking for Strata Mini parts
« Reply #1 on: 31 Dec 2011, 03:49 pm »
I have two of the tweeters left in stock. Just give me a call to order them. 940-592-3400
It is not likely a crossover part has failed. It sounds like a solder joint failed on you. That can be fixed.
