What speakers for this room?
trondareo
Re: What speakers for this room?
« Reply #20 on: 31 Dec 2011, 03:02 pm »
Wall mount omnis - now we´re onto something :D
Any body know of a DIY prject in this line?
dB Cooper
« Reply #21 on: 1 Jan 2012, 04:17 am »
Well, not DIY, but a wall mount omni: http://www.ohmspeakers.com/productline.cfm (scroll down about halfway to see the MicroWalsh Wall which unfortunately leads you to a larger pic of a different model); mysteriously absent from their price list, if you look into them tell them their website is in dire need of a refresh.
Jonathon Janusz
« Reply #22 on: 1 Jan 2012, 04:39 am »
Well, because he has been mentioned earlier, and you're looking for a DIY wall mount omni, how about Danny's AV1-RS:
http://gr-research.com/av-1rs.aspx
trondareo
« Reply #23 on: 1 Jan 2012, 12:37 pm »
Great! I think this is closing in on a interesting solution. It uses the ceiling for reflected dispersion of the sound, whicj might mean the sound stage will be very high in the room. but otherwise a compact, possibly cheap and cheerfull solution. I reminds me of some wall mounted up-lights. I could include LED´s on the surface to make uplight speakers!
Something like this:
