0 Members and 1 Guest are viewing this topic. Read 12359 times.
I am buying new monitors with a stated 86.5 db, 8 ohm. How many watts do I need to REALLY drive 86.5 speakers?
Yes indeed, thanks for all the advice and knowledge!I spoke with the owner of Jolida , He said I could use the variable outputs to connect the subwoofer. it has no sub outputs.Is there a problem connecting the sub to these outputs?Is this Classe amp an older model amp with warm sound?Todd
150 watts should be the perfect amount of watts for getting great dynamics with these speakers.
Some amps clip gracefully, and kindly tell you to turn it down. Others go into full bore oscillation; when you finish crapping your pants about what's happening to your system (and then turn it down), one may may consider buying a high wattage, high current amplifier.
