Macmini Server vs Standard Macmini for music?
0 Members and 1 Guest are viewing this topic. Read 1677 times.
fado
« on: 27 Dec 2011, 03:24 pm »
In the past, you have stated a preference for Macmini with Amarra for computer based music.
According to Apple, the Macmini Server and the standard Macmini have exactly the same audio components.  Looking only at the specifications below – would there be any reason to prefer one model over the other for sound quality/dedicated music, especially internet sourced music, use?  The cost to replace the server software with the standard software I think makes the two units price equivalent.  The only difference I see is the 2.0 Quad-Core vs the 2.7 Dual-Core.
Mac mini Server - $1599.00
•   2.0GHz Quad-Core Intel Core i7
•   8GB 1333MHz DDR3 SDRAM - 2x4GB
•   256GB Solid State Drive
Mac mini - $1699.00
•   2.7GHz Dual-Core Intel Core i7
audioengr
Re: Macmini Server vs Standard Macmini for music?
« Reply #1 on: 27 Dec 2011, 07:00 pm »
They should sound identical, unless there is some difference in the USB interfaces or OS.  I imagine they use the same motherboard.  I dont know OS differences.  This could be problematic.
Steve N.
