Can the Dodd/Virtue Battery PSU Feed 2 components?
0 Members and 1 Guest are viewing this topic. Read 2074 times.
jb26
« on: 25 Dec 2011, 01:14 pm »
Hi All,
I'm contemplating  upgrading to the Virtue/Dodd battery PSU sold through the Virtue website because, frankly, everybody raves about it and it seems like the next, most cost effective way to improve my system.
I currently run the M901 130/30 PSU with a DAC as the front end.  I would like to run both the M901 and the DAC off the one battery pack, is that possible?  Is it necessary?
James
jb26
Re: Can the Dodd/Virtue Battery PSU Feed 2 components?
« Reply #1 on: 28 Dec 2011, 07:11 am »
Anyone?
antonio
« Reply #2 on: 28 Dec 2011, 08:23 am »
yes, it's possible.
but before you have to know the input voltage of the DAC:
- if it is 24 v (same as m901), you can put input dac at same point of m901 input
- if it is 12 v you have to make a derivation from just one of battery
- if it has a different V input...no
antonio
p.s. what DAC have you?
jb26
« Reply #3 on: 28 Dec 2011, 12:47 pm »
Hi Antonio,
I have a peachtree idac, it seems that input voltage is 20W - from the specs it reads "Maximum power consumption: 20W".  So I must be out of luck.
I'm guessing that running the amp off the batteries would provide the bulk of the improvement anyway.
James
HAL
« Reply #4 on: 28 Dec 2011, 12:58 pm »
The power consumption is not the spec you need.  You need to find the voltage and current ratings for the DAC.
antonio
« Reply #5 on: 28 Dec 2011, 01:36 pm »
hey james,
i have had a look to a rear idac panel photo.
it doesn't seem to have a DC input, just AC plug.
so you can't feed a battery power without modifiing something and opening IDAC.
i think is better left standard ac input.
antonio
jb26
« Reply #6 on: 31 Dec 2011, 11:33 pm »
Thanks Antonio, happy new year.
