Confused with virtue amps
0 Members and 1 Guest are viewing this topic. Read 2042 times.
ricardojoa
« on: 15 Dec 2011, 02:48 pm »
Hi,
just wanted to know alittle bit more about virtue amp as i might consider one for a bedroom set up. But im a bit confused. Their power rating for one.2 are 24v/55 watts. Im guessing that they work on 24 volt? Instead of the tradiional 120volts? Im from oversea and the power voltage is 220volts, would i be able to use virtue?
What does the one.2 comes with?
Thank you ahead.
Re: Confused with virtue amps
« Reply #1 on: 15 Dec 2011, 07:07 pm »
The amps can run with 24 to 30 VDC. They can be powered by an external power supply fed with 120V or240V power or via batteries.
ricardojoa
« Reply #2 on: 16 Dec 2011, 09:15 am »
Thanks for the response. When purchasing them integrated amp, is the power suply fed included?
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
« Reply #3 on: 16 Dec 2011, 06:13 pm »
All amps come with a passable 24v/65w PSU.  Upgrading is a checkout option.  The tripath amps sound "tightest" (most smooth, analytical, quiet) with batteries.  I happen to prefer the open and airy sound of the switching supplies.
ricardojoa
« Reply #4 on: 16 Dec 2011, 10:55 pm »
Im guessing that the standard PSU is for 120v? Cause there is an upgrade PSU JT dynamic power listed as 240/115v.
virtue
    • Virtue Audio
« Reply #5 on: 16 Dec 2011, 11:20 pm »
Every psu supports 110v or 240v (universal).
ricardojoa
« Reply #6 on: 17 Dec 2011, 03:09 pm »
Thanks virtue for clearing out my confusion.
