Placing an amp on a chopping block
0 Members and 1 Guest are viewing this topic. Read 2774 times.
lordvader
« on: 14 Dec 2011, 12:48 pm »
Hi :)
So I've got a nice, heavy ( ~30kg) DIY amp, that's currently sitting on floorboards.
I've also got a nice heavy-ish (8kg) chopping block that I want to use as a stand for the amp.
Question I have, is what will be the best iso device to place between the chopping block and the floorboards ?
There are so many options, each seeming viable.
I'm currently torn between decoupling spikes (spike pointing up), or the ISO-cup .
Any advice will be MUCH appreciated !!!
johzel
Re: Placing an amp on a chopping block
« Reply #1 on: 14 Dec 2011, 02:47 pm »
Check out Stillpoints.
Herbie
    • Herbie's Audio Lab
« Reply #2 on: 14 Dec 2011, 05:35 pm »
Hi, lordvader. Yes, many different options would be viable and do very well between the platform and floor, including Stillpoints, decoupling spikes, Iso-Cups, Fat Dots. Extra-Thick grungebuster Dots are usually ideal though, and economical, between a chopping block and floor.
Equally important or moreso is the interface between the platform and the amp. You probably couldn't do better than Iso-Cups w/SuperSonic Hardballs.
Herbie's Audio Lab
