Tube amplifier for headphones
0 Members and 1 Guest are viewing this topic. Read 1989 times.
heavil
« on: 13 Dec 2011, 10:28 pm »
Hello! I would like to build an amplifier for headphones. I've found several popular schemes in the Net:
http://lonewolfblues.com/headphone.html
http://gilmore2.chem.northwestern.edu/projects/cmoy5_prj.htm
http://diyaudioprojects.com/Solid/Tube-Mosfet-Hybrid-Headphone-Amp/
Which of these schemes will you recommend for optimal work with headphones with resistance of 32 ohms?
jostber
Re: Tube amplifier for headphones
« Reply #1 on: 14 Dec 2011, 10:23 am »
Hi, you might get some answers here, but to get more feedback from DIY experts you might check the forums at www.head-fi.org and especially at http://www.diyaudio.com/forums/headphone-systems/
JakeJ
« Reply #2 on: 14 Dec 2011, 01:39 pm »
Don't forget our own Headphone Mania circle!  :thumb:
http://www.audiocircle.com/index.php?board=147.0
randytsuch
« Reply #3 on: 14 Dec 2011, 04:31 pm »
I don't have any experience with the amps you are looking at, but the middle one (morgan jones) has the best reputation.  There are also later derivations of that design.
Do you have experience with tube amps, or tube gear in general?  A standard tube amp generates lethal voltages, so it is not a project to be treated lightly.  For headphones, there are low voltage options available, that are safer.
If you are comfortable with the voltages, also a question of budget, and how much work you want to do.
There are places like this
http://glassjaraudio.com/
that sell pwbs or kits
Another place to look at amps is here
http://www.cavalliaudio.com/diy.html
Randy
jimbop
« Reply #4 on: 14 Dec 2011, 10:19 pm »
And Bottlehead:
http://www.bottlehead.com/store.php
Great reputation and great support forum.
adydula
« Reply #5 on: 14 Dec 2011, 10:34 pm »
SOHAii from Cavalli Audio....built one, excellent amp.
Good Luck
Alex
