Virtue 2.2 / 130 power supply volume clicks
0 Members and 1 Guest are viewing this topic. Read 2306 times.
jparkhur
« on: 3 Dec 2011, 04:50 am »
Hey, need some help. Hooked up a 2.2 to my new frugal horns with fostex 126en and when I change the volume there is a noticable click/step in the volume.  Is this normal or do I need to send this in.  Thanks for any help.  Jon
roymail
  • Roy in TX
Re: Virtue 2.2 / 130 power supply volume clicks
« Reply #1 on: 3 Dec 2011, 05:07 am »
Does it use a stepped attenuator?  If even it does, you should not hear a click, and the step up should be subtle.  I don't have one, so I can't comment further.  But, I do have a Goldpoint/Elma stepped attenuator that works great and steps smoothly.
jparkhur
« Reply #2 on: 3 Dec 2011, 05:15 am »
It's a stepped attenuated and it loud enough to be irritating.
roymail
  • Roy in TX
« Reply #3 on: 3 Dec 2011, 05:43 am »
It has an audible click with each step... not good. :roll:
jparkhur
« Reply #4 on: 3 Dec 2011, 02:55 pm »
Just plugged in my 1.2 with 130 ps and no click at all.   SuggestiOns
eclein
« Reply #5 on: 3 Dec 2011, 03:15 pm »
I have had a 2.2 for a year or so with the 30/130 and it never clicked once, I'd say something is amiss, better safe than sorry.
 Jason will probably read this....
Jason T
  • Enjoying the music
    • custom cables
« Reply #6 on: 3 Dec 2011, 06:23 pm »
Jon
it sounds to me like the pot is bad, lets get it to me so I can fix it for you.
please email Cami [email protected] and let her know your situation. she will help you in getting it back to us.
