D/A's
0 Members and 1 Guest are viewing this topic. Read 1295 times.
tvyankee
D/A's
« on: 30 Apr 2004, 04:58 pm »
Was wondering who makes a D/A that is not so expensive($500.000) and sounds really good.
Only needs to be 2ch and able to recieve one coax in and one optical in.
It should have at least a 24/96 D/A in it as well.
Thanks for your help in advance.
warnerwh
D/A's
« Reply #1 on: 30 Apr 2004, 08:31 pm »
Channel Island, Scott Nixon Tubedac are two excellent choices in our price range. I don't know if the Tubedac has both inputs though but the CIA does.
BikeWNC
D/A's
« Reply #2 on: 30 Apr 2004, 08:42 pm »
If you can stretch your budget to around $850 used, the Bel Canto Dac2 does all that you require and it sounds great too.
Andy
BTW - the SN Tube Dac does not upsample to 24/96.  But let's not turn this thread into a debate as to whether that is a good thing or not.
hmen
D/A's
« Reply #3 on: 6 May 2004, 06:22 pm »
For under $500 used, you could consider the Bel Canto DAC1.
