Best Entry-Level Phono Preamps for MC Cartridges
0 Members and 1 Guest are viewing this topic. Read 11963 times.
dlaloum
Re: Best Entry-Level Phono Preamps for MC Cartridges
« Reply #20 on: 3 Dec 2011, 01:29 am »
Depending on whether you have a Mac in your system, a pro-audio interface with Pure Vinyl providing the RIAA eq, can be a nice cost effective system.
I have a Focusrite Saffire interface that I have been using with an Ortofon HMC30 cartridge, that I have been pretty happy with.
I'll second that as a valid option...
For PC you can use Diamond Cut software...
Or there are several VSTplugin modules available which do RIAA
I use a PC with e-MU 1616m - the microphone inputs work fine - all that needs adjusting is the loading, which can be achiever with a parallel resistance.
SET Man
« Reply #21 on: 3 Dec 2011, 05:17 am »
That's what I was thinking. For the price of a new LOMC cartridge plus a step up device, you have to at least consider a high output MC.
Hey!
    The only down side of this is that your choices will be somewhat limited. But it is sure less complicated.
    Still I feel that if you already have a good MM phono pre than a good step-up transformer especially one with gain and loading options is a way to go in the long run I think.
Take care,
Buddy :thumb:
DaveyW
« Reply #22 on: 3 Dec 2011, 07:28 am »
Chipping in on this point.
With optimised resistive loading (Hi @ 1k ohms), I found it very, very difficult to tell the High and Low output versions of the Dynavector DV 20X apart.
It's a great cart too!
vortrex
« Reply #23 on: 3 Dec 2011, 09:05 am »
jolida JD9A without a doubt.
midfi
  • nisi credideritis, non intelligetis
« Reply #24 on: 15 Dec 2011, 10:56 pm »
I really like mine...
