The Most Holographic - 3D - Preamps You know Of.
0 Members and 1 Guest are viewing this topic. Read 71892 times.
Tomy2Tone
Re: The Most Holographic - 3D - Preamps You know Of.
« Reply #160 on: 29 Jan 2022, 10:03 pm »
It is dual mono, and has a regenerative power supply. When I first turned it on I thought it was broken because it was so quiet. Love my Sachs preamp too with the 6sn7's, and I like the looks more for sure, but this Audio-GD is pretty amazing sounding especially considering the price. And I have no desire to tube roll in it, sounds great as is. I think it really started to break in the last week or so (got it around xmas time) because last weekend I was blown by the imaging and soundstage, especially depth, like I've never heard before. There is also a solid state version for less money that is also supposed to sound great.
abd1- How much is the Audio-GD? Is it in the ballpark of the Don Sachs? Can’t seem to find a price on it.
Phil A
« Reply #161 on: 29 Jan 2022, 10:30 pm »
It's in the review linked in post number 133 - https://hometheaterhifi.com/reviews/amplifier/preamplifier/audio-gd-vacuum-he1-xlr-tube-preamplifier-review/
sunnydaze
screener
Tomy2Tone
« Reply #164 on: 29 Jan 2022, 11:58 pm »
Thanks for the links guys!
« Reply #165 on: 30 Jan 2022, 12:30 am »
So far the only pre-amp I had interest was the Gary Dodd battery powered, also the Mystere SRPP 6SN7 are not bad, is the case of a tube pre-amp the ideal are order one to your favorite builder with the best features.
Fancy brands assembled pre-amps are made to give large profits.
Kw6
« Reply #166 on: 30 Jan 2022, 04:09 am »
Agree electronic prices have been jacked sky high! For example love to try Bat pre amp bit for decent model looking at $20k!😕
abd1
    • DailyFrenchie
« Reply #167 on: 30 Jan 2022, 04:43 pm »
Contact Walter at Underwood. He often has specials on some of these.
bakufu
« Reply #168 on: 30 Jan 2022, 07:03 pm »
walter is definitely one of the Good Guys.
i purchased an ambrosia 2000 second edition from him a few years ago.  it's an end-game component in my solid-state system.
in my tube system i'm using a line magnetic AS-133 preamp.  again, i can't see any reason to search for an alternative.  the western-electric engineers knew what they were doing.
https://grantfidelity.com/new/index.php/product/analog-sound-by-line-magnetic-as-133-direct-heated-triode-2a3-tube-pre-amplifier/
Kw6
« Reply #169 on: 31 Jan 2022, 12:55 am »
Nice pre amp hoping for $2k budget like Audio gd!
Kw6
« Reply #170 on: 31 Jan 2022, 02:08 am »
Also been reading that best tube preamps use 6922 or the 6H23EB. What do you guys think? Other group seems to think 6SN7s are better?
« Reply #171 on: 31 Jan 2022, 02:17 am »
I suspect 6SN7/6SL7 are better due the big tone, but 6922/6DJ8/6N1P allow build a cheaper amp what are manufacturer purpose/profit, in the end what count are the personal taste there is no established truth.
Kw6
« Reply #172 on: 31 Jan 2022, 04:09 am »
But by using 6SN7 don't you have to pad it down a lot to get proper gain?
« Reply #173 on: 31 Jan 2022, 04:23 am »
How much is need?
If greater gain are need one could use 6SL7 = gain 70 x.
Kw6
« Reply #174 on: 31 Jan 2022, 05:31 am »
How much is need?
No mean 6SN7 has too much and need parts to throw away the signal!
« Reply #175 on: 31 Jan 2022, 05:54 am »
One always have the volume control.
« Reply #176 on: 31 Jan 2022, 07:10 am »
Agreed, if you have a moderate to high efficiency speaker with a high gain amp, a moderate or high gain preamp is probably not the best choice.  In my downstairs system I use low gain amps and a 6SN7 preamp, and it works nicely.
In my upstairs system I have high gain amps.  And high efficiency speakers.  I tried active preamps but they just had too much gain (and also introduced too much noise).  So for a long time I just used the Alps pot that was integrated in to my DAC.  And it was OK, but I always suspected that it was a bottleneck.  And I was right.  Lately I switched over to a Transformer based Volume Control (TVC) and wow it's MUCH better than my prior approaches.
mgalusha
« Reply #177 on: 31 Jan 2022, 07:17 pm »
I've been in the TVC camp for some years, it's the one component I never think about changing, it just changes the volume. With modern DAC's, many have enough voltage to drive most any amp into clipping and no gain is needed. Many phono stages do as well, I use a TVC with both of mine without a problem.
« Reply #178 on: 31 Jan 2022, 08:03 pm »
Well, since it's your TVC that I bought, clearly you were a smarter man than I was for a long time :D.
I will say this, with a pot, it only really sounded good when the volume was set at around 50% on the dial.  But with the TVC the volume sounds great at any and all settings.  Low level listening in particular is markedly better now.  It's like everything just lit up from within.
bakufu
« Reply #179 on: 31 Jan 2022, 09:07 pm »
walter is very enthusiastic about audio gd.
