RM 200 bias.............?
0 Members and 1 Guest are viewing this topic. Read 1705 times.
Bmotorcycle2003
« on: 19 Nov 2011, 10:52 am »
Roger, is there a way I can add two pots (one per channel) so I would be able to bias each tube independently.  I have over the years have had one tube go bad while its matched counterpart checks out fine.  I now have probably 6+ tubes that are not matched to any of the others so I really can't finish off using them.  If I were able to bias each tube independently I could than have the ability to use tubes after its mate has bit the dust.
Again Roger thanks for this forum...............Bob
Ericus Rex
Re: RM 200 bias.............?
« Reply #1 on: 19 Nov 2011, 01:32 pm »
The new Stereophile review of the RM200 MkII states that Roger can add individual bias pots to this amp.  It's an $800 option when buying new, probably more expensive to retrofit.  Check out the review for more info.
Roger A. Modjeski
« Reply #2 on: 2 Dec 2011, 07:45 pm »
Rather than add separate bias pots I went with a "bias balance" pot as it makes adjustment easier. I can retrofit one for $900 including the driver mod and give the amp a full check-over.
