Other Stuff
Archived Manufacturer Circles
Solar Hi-fi
Which speaker cables complemen Jena Labs interconnects?
0 Members and 1 Guest are viewing this topic. Read 6432 times.
Manolo
Consulting Structural Engineer
28 Apr 2004, 08:16 pm »
My interconnects are Jena labs, Symphony Digital, Trio and Fugue but their speaker cables , being so expensive, I was wondering if there is another more economical speaker wire alternative that might complement the Jena interconnects. Thanks
KevinW
11 May 2004, 03:04 pm »
Jena Labs has two affordable speaker cables that are outstanding performers. They are not as well known as their larger siblings, but have the same magical Jena sound. The Siamese 4 is $650 for an 8' pair, and the Gamma 6 is $900 for 8'. These are in the same price range as the Fugue and Symphony IC's. You can see pictures at
www.solarhifi.com/cables.php
The Gamma 6 also comes in a kit for those who are solder inclined and want to save significant $$. It is probably the easiest Jena Kit to wire up of all the kits they produce.
KevinW
Reply #2 on:
11 May 2004, 03:05 pm »
KevinW
Reply #3 on:
11 May 2004, 03:08 pm »
Other Stuff
Solar Hi-fi
