Free Music Player for Macs?
0 Members and 1 Guest are viewing this topic. Read 1697 times.
Sonny
« on: 17 Nov 2011, 05:41 am »
Hi there, lately, I am having issues with my iTunes (10.5 version).  It keeps locking up and I can't "force" it to quit.  Does anyone have this problem?  Also, some songs are listed "twice"/"duplicates" on the song list.  Don't know why as it's only there "once" in the database.
Is there a better player that is free?
Has anyone heard of Audirvana player>  http://audirvana.com/?
Advice/Comments appreciated.
skunark
Re: Free Music Player for Macs?
« Reply #1 on: 17 Nov 2011, 05:47 pm »
There are several free players like cog, Play and I believe even winamp is now available for the mac.
The most likely reasons you have duplicates in your library would be a) you actually have the files in two different locations on your computer, b)  you have imported your library and/or that song twice.
I would recommend reviewing the "information" pop-up for the duplicated songs to see what is going on.   You will have this same issue with any media manager out there so you will have to address this for how you see fit.  There is an option to display duplicates in iTunes which will help narrow down the issues.
I'm not getting any crashes, but if you are close to an Apple Store and can recreate the problem, take it in and ask.    Another option is to back up your files, and rebuild your iTunes library (several examples on the web).
Also consider having iTunes consolidate your library before you rebuild your iTunes library.   This won't remove any files, but will copy all songs to a single location with a pretty reasonable directory structure which you can then browse and review.
Doublej
« Reply #2 on: 17 Nov 2011, 08:17 pm »
To add to the list.
VLC
Songbird
pardales
Crimson
« Reply #4 on: 17 Nov 2011, 09:07 pm »
skunark
« Reply #5 on: 17 Nov 2011, 09:21 pm »
Click.
That list is becoming dated, but the OP was asking for Free, that list doesn't indicate which are free players.   Probably could use some alphabetization as well
click here for another incomplete list
newzooreview
« Reply #6 on: 19 Nov 2011, 05:19 pm »
I would highly recommend Decibel. It's $33, so not free but very close to it, and it clearly improves the sound of playback. It uses a 64-bit, custom developed audio engine (and no audio processing trickery).
http://sbooth.org/Decibel/
The developer still offers an older, free program called Play, but the sound is not as good as Decibel. I think it's very much worth supporting his work to pay the small cost of his newer program.
Good luck with it.
