Can I use my BCD-1 remote
0 Members and 1 Guest are viewing this topic. Read 1720 times.
Robert D
« on: 15 Nov 2011, 10:51 pm »
Can I use my BCD-1  remote to operate  my New BDP-1
If anybody can help it would be much appreciated
Robert
drummermitchell
Re: Can I use my BCD-1 remote
« Reply #1 on: 15 Nov 2011, 11:56 pm »
Robert,looks like you need the BR-2 remote(I have one )but looks like I'll be needing it soon.
BrysTony
« Reply #2 on: 16 Nov 2011, 12:04 am »
I think I read in another thread that you were going to get an iPad2.  It will do everything except power on/off.
Tony
Robert D
« Reply #3 on: 17 Nov 2011, 05:28 pm »
Tony
I'm not sure if i will Tony go with the iPad2
You are saying that the Bcd-1 Remote It will do everything except power on/off. ?
Let me know Thanks Robert
BrysTony
« Reply #4 on: 17 Nov 2011, 06:53 pm »
Robert,
I meant that the iPad2 (using the MPad ap) will control the BDP-1 except power on/off.  I have a BR2 remote and when I use it to control the BDP-1 it is necessary to switch the BR2 to D/A.  If it is switched to CD it does not control the BDP-1.  That likely means that the BCD remote will not work but I cannot confirm that .  Just try it and see what happens.
Tony
Marius
« Reply #5 on: 17 Nov 2011, 07:11 pm »
Hi Robert,
I love the fact that it does control the volume too, including the mute, which both are not dealt with by the iPad.
In fact because of that I have them both around me all the time.....the br2 is convenient for start/stop/pause. I must confess I find the other controls are less then adequate, because I feel the need to be able to see the loaded playlists.
 :thumb:
so your br2 might not control the BDA, but it will be very convenient to use next to the iPad, for volume control.
Hope you'll like it!
Marius
Robert,
Tony
JfTM
« Reply #6 on: 17 Nov 2011, 07:14 pm »
Ahhh tasks that children used to do  :wink:
