I think the question arises of just how much liquid is on the record....
.. I think a key thing to remember is that cheap-jack is not pursuing vinyl replay from a "High End" perspective.Scotty
(1) Cheap-Jack, I applaud your efforts to extract satisfying performance from budget components.(2) The question is, is this safe for us to try with more expensive stuff.(3) How do you clean your records?(4) Is this regular tap water you use?(5) Why don't you use a better cartridge, too risky?(6) Exactly what record player and cartridge are you using?(7) If you can't compare your system performance to more expensive system, what have you proven? neo
(1) I agree about the benefits of good set-up and things like turntable isolation.(2) Your approach to wet-play differs from other advocates in the amount of water used. Some others only mist the record rather than use a thick layer of water. Maybe a little less water containing a few drops of a wetting agent would be just as effective? (3) do you clean your records prior to play? (4)Some people say they tried wet-play and then those records had to be played wet after that, or they were noisy. Others say that there was no additional noise playing dry, after having been played wet. Any further comments?neo
