0 Members and 1 Guest are viewing this topic. Read 4037 times.
I have a question for Hugh.Will the AKSA 100 require any modifications to drive 4 Ohm speakers such as Magnepan 2.7s?Thanks
Pauly,I really need to know how many drivers, impedance, and how they are configured. Failing that, could you give me the URL and I'll have a gander and get back to you.I have a pet peeve with loudspeakers of impedance less than 2R, I doubt these are that low; usually four speakers or more are wired in series/parallel so that impedance is not too low.Cheers,Hugh
Dejan,I was beginning to wonder where you were! I'm glad you are back....
One point, I may be wrong, but impedance takes account of phase angle; it's all a part of the reactance calculation, isn't it? [\quote]In general terms, yes, it is. However, in practice, I find far too many people discussing the plain impedance without any side effects, and you can't disregard them because they are always there. The question is only by how much and in what way.Hugh, we worked out behinds off while developing my 1041 monitors on precisely this aspect. To cut a long story short, eventually (as in 6 months and say 10-11 crossovers later) we managed to get it all down to a minimum impedance of 6 ohms with a worst case phase angle of -25 degrees. To the amp, this is about 5 ohms worst case all told, and that in a small section only (app. 80....150 Hz), after which it all stays just above 8 ohms, fairly constant.The gruelling test was using the same amp to drive these, and then switching over to AR94s (volume adjusted for same loudness); most different behavior of the amp. A VERY interesting test.QuoteThe good questions in this forum are entirely to the credit of the AKSAphiles here; they seem to be much, much smarter than in other forums I've seen. Ben and I try to keep the physics and psychoacoustics connected in our explanations, and we are bloody lucky to have such a crowd buying Aspen pro ...So I've noticed. What you do not mention, and what I like about it, is that along the way, you do manage to pass on an awful lot of level headed info, just what younger users need because, most unfortunately, they don't have much opportunity to read it straight, no dressing.As I said, compare the questions here with the general circles and you'll see the difference; this is to the point, sane questions of relevance asked, over there it's mostly acquisition time, what do I buy.Anyway, I don't want to party crash, just couldn't resist expressing my satisfaction, that's all.Cheers,DVV
Hi, Dejan,Pleeze tell us more about these 1041 monitors of yours.Regards,Andy
