Icepower 125ASX2 C&C!
0 Members and 1 Guest are viewing this topic. Read 66340 times.
roscoeiii
Re: Icepower 125ASX2 C&C!
« Reply #40 on: 2 Jan 2012, 01:24 am »
ICEpower module amps are well known for running cool.
HT cOz
« Reply #41 on: 2 Jan 2012, 02:47 am »
Mine have never made it past luke warm. If they are just on they are cool.
Gopher
« Reply #42 on: 2 Jan 2012, 03:50 am »
Anyone know how these would compare to the ClassD audio offerings?  I've purchased a pair of speakers and have some concerns about my ability to power them with my existing amp.  This might be a great inexpensive stop gap.
Barry_NJ
  • So much media... So little time...
« Reply #43 on: 3 Jan 2012, 09:30 pm »
No more adds on AG... I wonder if he's done selling amps  :scratch:
Phil
« Reply #44 on: 3 Jan 2012, 09:36 pm »
Try email:  [email protected]
Needless to say, there is a bit of a time difference  :D
Barry_NJ
« Reply #45 on: 3 Jan 2012, 10:44 pm »
Thanks, I found a thread of his over at DIY Audio and put a post over there. If he doesn't reply to that, I'll try email  :thumb:
persisting1
« Reply #46 on: 3 Jan 2012, 11:09 pm »
Ghentxu said that he's sold out of his DIY amps and is redesigning/building new cases.  Says they will be ready this month.
persisting1
« Reply #47 on: 28 Jan 2012, 09:55 pm »
Seems like the pricing on these really went up  :o
timind
  • permanent vacation
« Reply #48 on: 28 Jan 2012, 11:37 pm »
Where do you see them listed?
persisting1
« Reply #49 on: 31 Jan 2012, 10:54 pm »
I don't believe they are available yet, but he does state pricing here.
http://www.diyaudio.com/forums/vendors-bazaar/193289-fs-icepower-125asx2-module-15.html#post2866108
The last page of that thread shows some of his new work and he states there will be a cheaper DIY kit.
Lyndon
« Reply #50 on: 31 Jan 2012, 11:14 pm »
Don't bark at me if I'm wrong, but if anyone might be interested, I think Sheldon Stokes may have his units up for sale.  I think he built both these units and some Hypex modules and was happier with the Hypex in his bi-amping with 'stat speakers.
He has an account here, but I don't know it.
You could fire him an email at diyaudio above with "stokessd", or go to his website, http://www.quadesl.com/
His price would probably be close to something mentioned above.
knireis
« Reply #51 on: 4 Feb 2012, 11:09 am »
I've searched quite a bit but cannot find a comparison between these and a hypex ucd and a ClassD amp. Anyone found some info?
Klaus7112
« Reply #52 on: 15 Feb 2012, 04:21 pm »
Well, I just saw the AD of AG, there is a cheaper kit, seems almost same as last year.
worker
« Reply #53 on: 28 Feb 2012, 01:19 am »
Hi, I received and built the Ghent Icepower kit.  This is my first build (did not build electronics before), and my first class D amp (I have a pioneer elite receiver that has regular ab amp) -- so I do not much to compare this too.  However below is my review (I found about this amp on this forum, and on diyaudio -- so figured will  spend some time writing -- hopefully it will help others)
power amplifier:  class D, 125x2 (stereo) 125 into 4 ohms (so less into 8ohm)
provider: Ghent ([email protected])
found at www.diyaudio.com:    http://www.diyaudio.com/forums/vendors-bazaar/193289-fs-icepower-125asx2-module-17.html#post2914721
price paid: see thread above for latest
Other equipment used
preamp
  DAC (used as USB Doc, but also has optical, RCA in)
  http://www.xshn.com/en/display.asp?id=89
source:
  windows 7 laptop, USB
  aimp3   media player
  192-320bps  MP3s
cables:
  12 awg from monoprice (strand count 87 wires, strand size 0.2mm od, corss sectional area 3.0mm sq)
   rca -- old generic
speakers
  Av123   X-LS
   http://www.hometheaterhifi.com/volume_13_3/onix-xls-speakers-8-2006.html
  overall connection:
windows7 laptop USB ->Xiang Pheng preamp RCA -> Ghent icepower 125asx2 -12awg cable -> X-LS (2 speakers)
Overall satisfaction: very satisfied
Description:
   Ghent's manual says - that prior knowledge of assembling audio gear required. I had no prior experience -- so I technically did not qualify
   But overall the assembly is easier than say installing a motherboard into a computer.
   The only difficult part was that I had solder one thing:  wires into the RCA input connectors
    Also if I would use the provider XLR input -- I would have to solder that in too (but i do not have any XLR equipment so I do not bother)
  I had to ran to radioshack and by various types of crimp terminals and crimpers (since I did not have any)
  Payment/shipping:  paid via paypal.  Item was shipped EMS shipping, packaging was very good. Ghent is typically pretty available via email.
I did not have to ship anything back/return or cancel.  So do not have experience on that front.  Although I would hope those things would be handled well as well.
Sound:
  Detailed, tight base, strong mids, somewhat less pronounced highs. Overall effortless in driving the speakers
  I used the 'tube buffer' preamp output and AIMP3 equalizer to increase the highs to my liking and now pretty happy
  If I have to choose what's outstanding -- is 60hz and above for the base.  Very tight and not muddy.
  And of course the power consumption if the class-d  and price/to performance ratio are very high
Assembly:
   as I said earlier: for newbies like myself, dealing with RCA connection (and I would assume with XLR) -- was difficult (but anything difficult, when done -- is satisfying)
It was also very difficult to fit the XLR input into the provided case -- it looked like a bit of a mismatch
Instructions:  good overall.  One problem that I was the the picture of connecting the RCA input to the board, did not specifically say which cable goes into where on the RCA terminals.
So first I soldered them wrong (ground and positive on the Left RCA was wrong) -- then I read the provided table on the earlier pages that the 'grey' wires where the ground -- and had to redo the soldering.  (I think Ghent has updated the manual by now)
Other:
the amplifier appears to be very sensitive to input problems.  For example if I accidently touch my USB cable (which is a bit loose on my laptop) -- the preamp -- makes a clicking noise -- the amp imediately shuts down the sound to the speakers (to protect them).  THen I have to restart the USB connection, restart the preamp -- and then restart the power amp.
So most people who have stable USB connection will probably not experience any of that
HT cOz
« Reply #54 on: 28 Feb 2012, 05:17 am »
Worker,
Welcome.  This is a nice project.  It's an amazing little amp.
 :thumb:
Phil
« Reply #55 on: 11 Mar 2012, 06:43 pm »
Not to clog the airwaves, but I'm selling a new/unused module for $175 shipped and including paypal fee.
Please see my FS post and gallery if interested.  In short, I'm going to try the Hypex Ncore.  Not cheap but hopefully cheerful.
I'm still keeping my ICE amp as a backup, and until the Ncores arrive, as my main amp.  Thank you to those who started this thread.  It got me going in the class D direction.   :thumb:
Phil
Ajani
« Reply #56 on: 20 Apr 2012, 12:12 am »
I notice these amps are available for sale again on A'gon.
http://app.audiogon.com/listings/b-o-icepower-125asx2-a000b-monoblock-550w-se-ampl--2
Has anyone had a chance to compare them to the Class D Audio SDS line? Or even just any new user reviews?
lad-dog
« Reply #57 on: 24 May 2012, 06:46 pm »
I just purchased this amp from Ghent.  I purchased the A000B version (65X2 8 ohm, 125X2 4ohm).  I will let everyone know what I think when I get it.  I have become very interested in these amps since I found out they have the same ice module as the Belcanto S300 which a friend of mine has and is simply just amazing!  Incredible power with a very delicate, and smooth musical sound.  I will let everyone know my thoughts on this amp...if it gives me 80-90% of the Belcanto sound I may find myself upgrading to the A200B version that offers at least 250X2 into 8 ohms and 550X2 into 4 ohms.  I just upgraded my speakers to Totem Model 1 Signatures and I have a feeling I may need the extra power to get them to their full potential.
Ajani
« Reply #58 on: 25 May 2012, 01:29 pm »
 :thumb:
Looking forward to your review!
lad-dog
« Reply #59 on: 31 May 2012, 12:24 am »
So I got my Icepower 125ASX2 (A000B) a few days ago.  When I first opened it I was surprised.  I knew this would be small...but it is even small than I thought.  Perfect for someone like me that has limited real estate for my audio setup.  I have been letting it burn in for a few days before I really wanted to do some critical listening.  First impressions are extremely positive.  This amp has a very detailed and smooth sound.  Bass is very defined and tight!  Oh..and this amp is dead quiet and runs very cool so it certainly won't have you cussing out the power company.  My buddy is bring over his Bel Canto so we can compare this weekend but I have a feeling this amp will definitely hold its own!  I highly recommend this amp to those on the fence!
