Eyeball prototype
0 Members and 1 Guest are viewing this topic. Read 4504 times.
JohnR
Eyeball prototype
« on: 1 Nov 2011, 12:41 pm »
jtwrace
    • TIPP YouTube Channel
Re: Eyeball prototype
« Reply #1 on: 1 Nov 2011, 12:57 pm »
JohnR
« Reply #2 on: 1 Nov 2011, 01:00 pm »
C'mon, this is The Lab, isn't it? You know - what's on the slab?
« Reply #3 on: 1 Nov 2011, 01:08 pm »
It looks like a tweeter, but obviously it's your new acoustic foam footers.
JohnR
« Reply #4 on: 1 Nov 2011, 01:11 pm »
Heh. It's just a tweeter in a spherical enclosure made from Ikea salad bowls.
Tweeter is the Aurasound NSW2.
jtwrace
« Reply #5 on: 1 Nov 2011, 01:16 pm »
Oh great, just what we need...IKEA in the audio biz.   :duh:
JohnR
« Reply #6 on: 1 Nov 2011, 01:19 pm »
Nothing new there. Just cheap raw materials.
Blackmore
« Reply #7 on: 1 Nov 2011, 03:12 pm »
That's pretty cool looking.  Wonder if they make a bowl big enough for my Lowthers?
SET Man
« Reply #8 on: 2 Nov 2011, 01:59 am »
Hey!
     :lol: I thought about doing the same thing the last time I went to Ikea and saw those wooden bowls.
Take care,
Buddy :thumb:
JohnR
« Reply #9 on: 2 Nov 2011, 10:26 am »
Mark, Buddy: heck it's pretty easy stuff to work with! The finish on this one is a bit rough, I'll buy a hole saw the correct size for the final version (if I get that far).
Here's the eyeball set up for measuring:
JohnR
« Reply #10 on: 2 Nov 2011, 10:50 am »
As you know, you can take a thousand measurements. To cut it down to two, this is the raw "in-room" response, with the mic at 1m and the speaker 1.1m from the floor. Shown with 30, 60, and 90 degree responses as well. The on-axis boost 200-300 is floor/ceiling bounce reinforcement, I believe.
This graph shows the on-axis, 30, 60 90, 120, 150 degree measurements with a 2 ms gate, after equalizing the on-axis response to flat, shown from 1 kHz up:
It's interesting that with a driver that plays down to 200 Hz, you can listen to it fullrange as long as you're careful with the choice of music. Once the EQ is in, I'd say it's promising although not the ultimate.
JohnR
« Reply #11 on: 22 Nov 2011, 07:29 am »
Finally got a bit more time to experiment with these. Here's the eyeball atop a sealed JX92s. I've been experimenting with crossovers at 300 and 800 Hz so far. Currently the bottom end is provided by a sub (just visible in pic below)
On the other side, I tried something different:
