Mpad confused?
0 Members and 1 Guest are viewing this topic. Read 1094 times.
Marius
Mpad confused?
« on: 1 Nov 2011, 08:44 am »
Hi,
yesterday loaded a bunch of newly ripped songs onto the HDD. took forever, and  the BDP1 did not get out of the updating process. Finally, after at least one hour, I decided to reboot BDP1 through Max. did not help either, so I rebooted it with the power button.
This morning I took the iPad and browsed  my way to Relayer. Playing fine, but showing:
to check I went to Max:
Mpad seems confused?
I loaded the whole disc in a playlist in Max:
and this is Mpad showing it, all mixed up, different cd's an artist all together:
Now what on earth could be the reason for this? HDD is looking good, I checked with the disk utility . Only special thing I could mention is that in loading songs onto the HDD, I used a direct usb connection instead of the network. Went fine though.
Anyone? I already updated databases in Mpad and BDP1. :scratch:
Marius
  • The Demo is Everything!
    • http://www.bryston.com
Re: Mpad confused?
« Reply #1 on: 1 Nov 2011, 10:07 am »
Hi Maris
Try reloading mpad using the double click then deleting the icon then reload.
James
Marius
Re: Mpad confused?
« Reply #2 on: 1 Nov 2011, 10:24 am »
HI James,
Yep, that did the trick, but not after the iPad losing its complete network connection. Had to reset the iPad, and now we're rolling again.
Thanks, was kinda weird though.
Marius
