0 Members and 1 Guest are viewing this topic. Read 7138 times.
Q- Does a tube amp provide as much bass slam as a decent SS? If any ST's owners reading this have compared tube/ SS amps with their speakers, I'd be grateful for feedback on the pros and cons. many thanks
>>Q- Does a tube amp provide as much bass slam as a decent SS? If any ST's owners reading this have compared tube/ SS amps with their speakers, I'd be grateful for feedback on the pros and cons. many thanks<<SS has what I call vitality, that tubes lack. Fast, aggressive, quick response, whereas tube sound lags, slow response, mellow for lack of a better term.You really have to listen to both to know which you prefer.
........I just got thru listening to Gordon Goodwins "Property Of Gordon Goodwin's Big Phat Band XXL "http://www.amazon.com/Property-Gordon-Goodwins-Phat-Band/dp/B0000CABHC/ref=sr_1_1?ie=UTF8&qid=1320100694&sr=8-1Play this really loud and if you survive, You will have no doubt if your amp and your songtowers are fast or slow. period.........
To get the "tube" sound I much prefer a tube preamp or DAC; my amp will always be solid state due to reasons explained above. Do you mean you have a tube pre amp and ss power amp combo now? How does the dac fit in re tubes? My integrated ss is doing well, though i do remember the pleasing warmth and soundstage I heard on the songtowers/ ultra valve pairing. But it was such a quick listen I didn't have time to get very far in my comparison.Not trying to ignite the old tube vs ss amp debate, but really appreciate the various songtower owner's experience. Thanks again.Tom
The SongTowers are an easy load to drive so a tubed amp will work just fine. A decent 40 to 50 watt integrated like a Jolida or Rogue would be cool. Tubed amps on difficult loads like HT3's or SoundScapes require more sophisticated designs and much more moola to get control of those woofers and integrate well.If you are after ST's performing in a primarily 2 channel set-up then the world is your oyster when it comes to low cost amps.Most of us, not all, enjoy the tubed pre and SS amp combo. With the ST's I would be less concerned about controlling those smaller woofers with a tube amp and enjoy.
Hey Bigg'n:In regard to HT2-TL's what type and power tube amp would you recommend?
I'm pretty confident these will work:http://www.tuberesearchlabs.com/products/gt400.htm
