0 Members and 1 Guest are viewing this topic. Read 13275 times.
Jim, i didnt know you do these type of custom design
That's for Dennis or Jim. I would say the Fountek is close but not quite a smooth. But if you are trying to get the price lower it sounds like a decent option.
Dennis and/or Jim,Can you describe the difference among the woofers used by SalkSound: Excel vs. Illuminator vs. Accuton? Thank you.
What physical size are they?Wayner
Apparently, no one has a tape measure.
I've used the Fountek in quite a few designs. I would say its performance is midway between a good dome and the RAAL. It can be crossed fairly low and has an open, clean sound. Just not as open as the RAAL. But without the RAAL for direct comparison, I think anyone would be very pleased with the Fountek. Excellent value as well.
How does the Fountek compare to the LCY or G2?
