Bent Audio
Braam
Bent Audio
« on: 12 Mar 2026, 11:10 pm »
Hi,
I built a Bent Audio NOH preamp many moons ago and is now in need of an instruction manual as I have forgotten the function of some of the switches(I'm 75!)
Can anybody  help?
I'm trying to connect to John Chapman but my info might be outdated.
Thanks.
Re: Bent Audio
« Reply #1 on: 13 Mar 2026, 12:54 am »
Hi,
Can anybody  help?
Thanks.
There is the TAP-X manual it may be similar.
https://bent-audio.manymanuals-pt.com/
opnly bafld
Re: Bent Audio
« Reply #2 on: 13 Mar 2026, 01:17 am »
Left input selector Center volume control Right input selector. Remove the top and you should be able to see/confirm.
Phil A
Re: Bent Audio
« Reply #3 on: 13 Mar 2026, 01:31 am »
Welcome!
Re: Bent Audio
« Reply #4 on: 14 Mar 2026, 05:20 am »
Greetings & Welcome to AC  Braam   :thumb:
