Log In Problem
0 Members and 3 Guests are viewing this topic. Read 3755 times.
David Morasco
  • Guest
Re: Log In Problem
« Reply #20 on: 6 Feb 2026, 12:34 am »
On January 14, I used the "Forgot Password" page to change the password I had been using.
I just tried to log in with this recently changed password and I got the same message/screen:
•   Login
An Error Has Occurred!_____________________________________________________________
That username does not exist._______________________________________________________
        Back
I am not optimistic that changing the password again will fix this.
David Morasco
  • Guest
Re: Log In Problem
« Reply #21 on: 6 Feb 2026, 03:08 am »
I changed the password.  I later logged out and then tried to Log In.  Exact same error message as in my previous post (12:34 am).
For quite a while now (when I was able to log in), I have had to log in twice. The 1st time it says Incorrect Password.  The second time, using the identical password, it lets me in.  I had inquired about this when it first happened and I did not hear anything back.  I just kept logging in twice - until this latest issue.
I have changed the password twice and this has not fixed the issue.  Clearly with the dual log ins and the error message (which is incorrect - the username does exist) there is something else wrong.
ServerAdmin
Re: Log In Problem
« Reply #22 on: 6 Feb 2026, 08:11 am »
To clarify : after changing the password, you were then able to log in?
David Morasco
  • Guest
Re: Log In Problem
« Reply #23 on: 7 Feb 2026, 04:01 pm »
Yes.  Each time I changed the password I got in.
After I exited and later tried to return, both times I got the same error message:
•   Login
An Error Has Occurred!_______________________________________ ______________________
That username does not exist._________________________________ ______________________
        Back
ServerAdmin
Re: Log In Problem
« Reply #24 on: 9 Feb 2026, 03:29 am »
It must be something to do with your browser. You could try incognito mode to see if you still get the same issue, clear all stored data, or better use a different browser (that you haven't used to log in with before).
David Morasco
  • Guest
Re: Log In Problem
« Reply #25 on: 9 Feb 2026, 04:16 pm »
It is the same browser I have been using for years and it works fine with everything else.
I am not going to use another browser.
Please close my account.
