FS: Martin Logan Electro Motion R Ceiling Speakers NEW $285 EACH
0 Members and 1 Guest are viewing this topic. Read 2217 times.
getech
Brand new, factory sealed "A" stock.  PRICE IS PER SPEAKER.
Application   In-Ceiling
Frequency Response   37–25kHz ±3dB
Dispersion   80° x 80°
Sensitivity   92 dB/2.83 volts/meter
Nominal Impedance   4 Ohms. Compatible with 4, 6 or 8 ohm rated amplifiers.
Recommended Amplifier Power   20-300 watts per channel
Crossover Frequency   2,600 Hz
High Frequency Transducer   1" x 1.4" (2.6cm x 3.6cm) Folded Motion Transducer with 5.25" x 1.75" (13.3cm x 4.4cm) diaphragm.
Low Frequency Driver   8" (20.3cm) aluminum cone with cast aluminum basket. Concave dust cap.
Weight   8lbs. (3.63kg) each
Overall Dimensions   11.5" (29.3cm) Diameter
6" (15.2cm) Depth
Cut-Out Dimensions   10.5" (26.7cm) Diameter
Depth Required Behind Wall Surface   5.9" (15cm)
Projection From Wall Surface   .125" (.3cm)
