What the heck is a HARP device?
Re: What the heck is a HARP device?
« Reply #40 on: 28 Aug 2025, 04:53 pm »
Looks a 70V line transforner used in commercial speakers. IMO
KTS
« Reply #41 on: 28 Aug 2025, 05:30 pm »
This discussion is super interesting, but well beyond my ability to comprehend the technical side, would someone be able to purchase the jumpers and attach between the crossover and the binding post inside the speaker? If you purchase from the manufacturer no harm done.
Mike B.
« Reply #42 on: 28 Aug 2025, 06:10 pm »
The patent Maty posted is a not HARP. On a side note, Rochelle Salt and Tourmaline power are effective in absorbing RF noise IMO.
Danny Richie
« Reply #43 on: 3 Sep 2025, 11:44 pm »
The HARP device really doesn't address RF or EMI. It actually defuses or damps out the resonances of the cable and dielectric material.
lifewithmusic
« Reply #44 on: 25 Feb 2026, 05:05 pm »
Danny, your website doesn't appear to show any products with teh HARP device technology. Did you stop using it?
Danny Richie
« Reply #45 on: 27 Feb 2026, 05:25 pm »
We do not sell or offer them.
They are exclusively used in our Allie and Maddie model speakers that are in production right now.
1OldRocker
« Reply #46 on: 1 Mar 2026, 08:57 pm »
Also in the X-LS Encore Extreme, is that correct?
Danny Richie
« Reply #47 on: 2 Mar 2026, 05:40 pm »
That is correct.
Dahodevil
« Reply #48 on: 23 Mar 2026, 03:19 pm »
I’ve heard the Harp device at Danny’s place. He can clip them on and unclip them. The difference is astonishing.  It’s exactly as he describes it. Without the harp device, his system reveals so much detail. You can hear all the instruments clearly placed. Once he connects the Harp device it’s like all the fuzziness between the instruments goes away and everything is so crystal clear and separated.  It is not subtle.
Beerbellydad
« Reply #49 on: 24 Mar 2026, 07:41 pm »
I understand why this would be a proprietary offering. Hearing about the benefits they add, would you consider offering them in the future to known GR customers that have purchased kits from you? I have a few sets of GR speakers and would definitely consider hotrodding a pair or two. (even privately, and not offered on the website)
Danny Richie
« Reply #50 on: 1 Apr 2026, 10:38 pm »
I can't. I can only offer then in a product.
nrenter
« Reply #51 on: 5 Apr 2026, 11:29 am »
US 6,545,213 patent / Caelin Gabriel (Shunyata Research)
Method and product for reducing distortion in an audio or home theater cable
https://patents.google.com/patent/US6545213B1/en
[PDF] https://patentimages.storage.googleapis.com/ce/d6/8b/e0af137bdb7731/US6545213.pdf
Isn’t this what Purist Audio Design does?
