I cannot seem to be able to set up my BDP-1 to utilize this feature!
Here is the step by step procedure I have tried and failed. Please point me to the correct direction, because I very much want to make this feature work!
Ok, I'm using a 32 GB USB thumb drive to set this up.
1. Hooked it up to my MacBookPro, and formatted it to MS-DOS (FAT32)
2. Plugged that thumb drive to BDP-1, turned it on.
3. After the BDP-1 finished booting up, went to "bryston-bdp-1.local"
4. Chose "Setting", and in "Drive Information", all the 2 drives connected to the BDP-1 were recognized and listed there.
5. Selected the USB thumb drive, then chose "Set Scratch Drive"
6. The BDP1 prompted for a "Restart" , clicked OK
7. After the BDP-1 finished restarting, I chose "Album Art DB" in "Setting".
8. I then clicked on "Build Album DB". The "Create DB Status lighted green for about 2, 3 minutes, then there're "codes" appeared in the window above the "Create DB Status" button. In these "codes", there a lot of album's names & information, and I notice that the line " FAILED OPENED xxx.." appeared A LOT.
9. Refreshing "bryston-bdp-1.local" and it did not show any album arts at all!
I tried this quite a few times with no success!
What did I do wrong here?
Please advise!
Hoa
P.S When I create playlist to play, albums with art covers shows correctly when chose "Current" or "current by album" When the song is playing, album art appears correctly at the lower left corner, so I dont think there's any problem with the embedded album arts in my files.
Also, there's one time during one of these trials, this error message showed up:
NOT FOUND
the requested URL/shm/albumdb.log was not found on this server
Apache/2.2.16 (Debian) PHP/5.3.3-7+squeeze1 with Suhosin-Patch Server at bryston-bdp-1.local Port 80
Dont know what that means!
