0 Members and 1 Guest are viewing this topic. Read 7136 times.
About the only advantage I can think of is maybe it might somehow bring less noise into the system(batteries) and that I'll have a lower power bill.
From what I understand the Astron draws big power at idle. A charged battery is a charged battery right ? It's not going to keep pulling power like the linear. Just a guess on that.
My Astron would be considered comparable to your supply, except that it's a big regulated linear supply and yours is a switching unit.
The JT Dynamic power supply is not a switch-mode power supply. It is a linear unregulated supply based on the Antek PS-3N30. It is also a 10A unit, so aside from the regulated vs unregulated aspect, I would agree they probably give very similar performance, and one could probably assume that if you preferred the battery supply to your Astron you would likely also prefer the battery supply to the JT Dynamic. Steve
Can someone guide me on how to use battery with my early Virtue Two (not Two.2)?Thanks in advance!
