0 Members and 1 Guest are viewing this topic. Read 30290 times.
I wish I had a stock Two.2 so I could more accurately guage just how much of an improvement there is.
No sir, the only caps I have in there now are the .1uf Claritycaps which replaced the Virtuecaps. The Auricaps simply don't exist in there any more, I have no fullrange on this particular amp.
Why didn't you opt for the 2.2uf Claritycaps?
We've done it again this is a pair of Dueland Alexander .1uf copper foil caps. you can see the 2.2uf virtue caps under the huge Dueland caps
500 hours plus?? I believe those caps are used in the top of the line Magnestand MMG speaker mod, and I'll be opting for those. I think the caps he uses are still secret but I'd bet the farm they're Duelands. I think the last final final thing I can now do to my amp, since I got it on batteries now, is eventually get one of dBe's Battery Busses on it.
OzarkTom,Your top picture shows the .1uf bypass cap. But I don't see them in the finished product. Are you bypassing the new Dueland's?Thanks for the review!Scott
Wouldn't a replacement of the 2.2uf caps be a much more significant upgrade - assuming they would fit?
