0 Members and 1 Guest are viewing this topic. Read 17827 times.
I now have a video on YouTube that compares the resonant properties of three materials: 13ply 3/4" plywood, 1" thick Richlite, and 3/4" MDF. Each panel is suspended by a wire and tapped with a hammer. Check it out.http://www.youtube.com/watch?v=SkSxH40x5SAWayne
The plywood is inherently self-damping because of all the plys -- the interface between each ply has a change of impedance which damps things. Not as inherently well damped as a constrained layer, but with none of the construction issues. The only panel damping is that supplied by the 1/2" recycled cotton felt that inherently lines the walls.Test builds are examined with a mechanics stethescope, and if anything significant can be heard thru the panels, more bracing is applied.A too resonant test build will be discarded or have an additional layer of material applied. Sometimes dissimilar.dave
Sorry, what is CSS?
