0 Members and 1 Guest are viewing this topic. Read 11472 times.
Up to this point, if you wanted a PORTABLE digital transport for flac files, you were really restricted to the iRiver H-120/140 with its mini toslink output and Rockbox. -Jim
This is very intriguing especially (for me) the use of this program and an iPhone 4 with a portable USB DAC. I wonder if the Emmeline Predator is Class 2 and 24/96? I'm surprised there isn't more excitement on Headfi about this.Up to this point, if you wanted a PORTABLE digital transport for flac files, you were really restricted to the iRiver H-120/140 with its mini toslink output and Rockbox. -Jim
Any point of view on good portable USB Dacs? I was looking at the streamers, but they need ac power. I'm thinking airplane here. Would love a way to listen high quality to the iPad while traveling. Sounds like the software is there, but is there any Dac/amp solution that's small enough and bus powered?Jim
Jim, I would like to know what you are using for headphones that give you enough isolation to appreciate the higher quality sound.
My Etymotic 4RS's isolate the heck out of airplane travel. I can't ehar anything other than background engine noise...but can clealry discern great recordings and great resolution.Jim, I will do some digging as to good USB portable DACs. My Meier Corda Move amp is wonderful but I don't use it's USB capability in the air, just as a headphone amp for travel.
