0 Members and 1 Guest are viewing this topic. Read 10190 times.
Well, well, well, and my, my, my! It's Grace Ruby Can't stay away, huh?I check in every two weeks or so, too.
Wanted to ask in the original thread, but it's locked.How does this tweak compare with the typical Thiele network used in many amplifiers?Here's a quick link for reference,https://www.circuitbasics.com/design-hi-fi-audio-amplifier-lm3886/#The-Thiele-Network
I believe Ric Schultz is EVS (ground enhancers) and Rick Schultz is High Fidelity or the magnetic based products you speak of. IOW, two different Schultz's.
Now my preamp inverts (tubes) so I have to change the speaker cables to adjust for that, which means the + connector on the amp end is connected to the - on the speaker end, and so on.
Gien that recordings have no “absolute phase” standard, so you are as likely to be wrong as you are right (ignoring the sw that has abs phase all over the place). If one wants to preserve absolute phase you need a phase switch on your pre-amp and you will need to note which LPs/CDs/songs have which phase.Your analness is gainign you nothing. One of the things i hate about the ACAs is that the 5-way posts are connected backwards for the same reason you are being anal.dave
