0 Members and 1 Guest are viewing this topic. Read 14978 times.
Bill, I've had to go up to Coolangatta 3 times this year already... next time I'll have to drop you a line first and see if there's any chance of syncing up, I'd love to hear some of this first-hand.
What are the effects of the Audiophilleos Signal "transpose" settings? You know, the "digital cable difference/Rise-time" simulator that I read about on their site when you connect it directly to the BNC plug on a dac.? Have you looked into that?
What are the effects of the Audiophilleos Signal "transpose" settings?You know, the "digital cable difference/Rise-time" simulator that I read about on their site whenyou connect it directly to the BNC plug on a dac.?Have you looked into that?Imp.
TomS,I meant to ask you two things:- what improvement did you notice in using an external 5V supply on the AP1?- Did you ever try the jitterSimulator & how would you describe the sound of th extra jitter?One thing I've been suggesting for a while now is to use RF attenuators on SPDIF devices. I suggested on SNA is to try an RF attenuator on the AP2. I (& lots of others) have found that these devices work to reduce any digital glare - it is thought by reducing reflections. Sometimes, we don't even notice this until it's gone. There's a good write-up on the technical aspects of these on this forum http://www.audiocircle.com/index.php?topic=90454.0
There's no doubt that these two devices are both achieving high levels of performance & can now compete with some of the best CD playback sources. I didn't ask this on SNA but I'll ask it here - I presume you were comparing files stored in 16/44 format Vs CD playback via the Marantz? Did you listen to high-res files? These should easily surpass CD playback
Good question and we did. We played Ella and Louis in Hi Res and down-sampled to regular 44.1/16. This is one of the first times I heard a difference in favor of the Hi Res - not much mind you - but it was there.ThanksBill
Was the Ella & Louis a true high-res recording & not just a 16/44 upsampled? Too many of these recordings being sold as high-res have been shown, on analysis, to have a sharp cut-off at 20KHz - signifying a brickwall filter! The reason I ask is because I notice a significant difference with true high-res material but I haven't down-sampled it to 16/44
