0 Members and 1 Guest are viewing this topic. Read 7018 times.
You tried a cheater plug. But have you tried having only 1 component actually grounded? I'd ground the amp, then use cheaters on ALL other components and see what happens. If you still have hum then, I'd suspect a tube is the culprit.
Sounds like a tube issue. Check your connections as well.charles
Wayner: by the way, the hum only is present after turning on the krell and it passes out of it's initial protection circuit.
That's a bit like saying 'my car makes this funny engine noise, but only when it's running.' The hum wouldn't be sent to your speakers until the amp is up and running.
