0 Members and 1 Guest are viewing this topic. Read 8442 times.
Found a pre amp I think could be a good match for Hugh's amps:http://www.audioasylum.com/forums/am...15/152892.html
Rubbish. The GK-1 is a fine preamp, and is a true preamp that has an actual gain stage.If a completely passive unit is desired, then George Stansfield's Lightspeed is ideal. If something cheap and simple is desired, then just wiring in attenuators on the input to the amp module works well.
Hi GuysFound a pre amp I think could be a good match for Hugh's amps:http://www.audioasylum.com/forums/am...15/152892.html
Could you repost the link, this one doesn't seem to work.
Sorry can't agree with you there. Bill
The main reason for posting is at least two people including myself are getting it for the express purpose of powering a NAKSA. I simply thought people would be interested the pairing - thats all.ThanksBill
