Arte Forma Audio -- EL34/6P3P push-pull tube amplifier
0 Members and 1 Guest are viewing this topic. Read 1737 times.
Normanyang
Arte Forma Audio 2011 new release. 25W + 25W, EL34 or 6P3P x 4 (we recommend to use 6P3P tubes), 12AX7 x 2, 12AU7 x 2. Push pull circuit. Remote included. We will use JJ ECC83S x  2, ECC82 x 2 and Shuguang 6P3P as our standard tubes.
MSRP : $1299.
« Last Edit: 22 Jan 2011, 11:49 am by Normanyang »
Wind Chaser
Re: Arte Forma Audio -- EL34/6P3P push-pull tube amplifier
« Reply #1 on: 21 Jan 2011, 12:13 pm »
How does this unit sound different from the 150 watt amp?  And what are the stock tubes, Shuguang?  Can the amp be purchased without the stock tubes?
Remote available
MSRP : $1099.
Is the remote included or is that extra?
Normanyang
« Reply #2 on: 21 Jan 2011, 02:31 pm »
Solid-state amp is better in sound stage and dynamic performance, but tube amp is strong at sound smooth and motion parts. They are difference type of amplifier.
We use China Shugang tubes as our stock tubes, it's workable to purchase without the stock tubes. Our price will be $1150.
All our price is renmote included.
Aluminum material remote controller
« Last Edit: 22 Jan 2011, 05:16 am by Normanyang »
rpf
« Reply #3 on: 21 Jan 2011, 02:41 pm »
Why do you recommend the 6P3P tubes over the EL34?
How do they sound different?
Normanyang
« Reply #4 on: 21 Jan 2011, 02:51 pm »
First, 6P3P is very cheap and do not hype by collector yet. You are hardly to find the power tube under $20/pcs.  6P3P unit price is $12/pcs.
Secondly, we agree the EL34 tube is better at bass performance( compare with 6P3P ). But 6P3P tube have the special taste in vocal performance.
Since 6P3P tubes are not expensive, why do not choice them?
rpf
« Reply #5 on: 21 Jan 2011, 04:52 pm »
Thanks for the info.
Normanyang
« Reply #6 on: 21 Jan 2011, 05:28 pm »
Welcome! We guess the 6P3P sound taste special due to the bottle shape is almost same as 300B/2A3. It makes sound better.
« Last Edit: 31 Jan 2011, 03:01 pm by Normanyang »
