0 Members and 1 Guest are viewing this topic. Read 25066 times.
LapsanWhich model spectron specificly did you own.I also have sp techs, the continuum 2.5s. Love emthxBrett
In my case, it's only because I would be repeating what I've posted previously. That is, in summary, I'm a happy owner of two Cherry Pluses. Replaced highly regarded tube amps, a Music Reference RM9 Mk II, and Wolcott Presence monoblocks. Main speakers are Merlin VSMs, of somewhat recent vintage, used for two channel music and the mains for home theater. Surround speakers are Merlin TSMs. Will eventually add a fifth channel of Cherry for the center channel Merlin TSM, where it will replace a Bryston 300 WPC monoblock. Don't miss the tubes at all. Never heard the Spectrons so have no comment.
After you've posted your input once, I think the expectation is for people to find it in a search, and not repeat it every time someone asks, "What do you think?" Especially if you are happy. And with DAC, with no disrespect and without really knowing, I doubt there is a huge installed base of users to even draw on.End result, no buzz. Didn't stop me from listening and buying.
Agree 100%. In my case, I was lucky to borrow a 4800a before committing, and it kicked all other Class D amps that I've heard, both in my system and elsewhere, to the curb. The Cherry Jr. was a step up from the 4800a, likely because of component changes since the 4800a was introduced. You can look at my previous thoughts on the subject in this circle if you haven't already done so. The particular 4800a that I borrowed was Lapsan's, so there is some ability to compare how well even the lowest model performed in multiple systems and setups.I would also say my search was not exhaustive among all available Class D offerings (only those within a limited price range), and that I have not directly compared in my system, for instance, tube amps to the DAC amps. However, I'm also not feeling a strong need to do so as there is a certain synergy that I feel has been attained among the components I now have.FWIW, I agree 100% with the characterizations of the DAC amps you can find in the latest reviews of the Jr. and PLUS. What the reviewers heard, I also heard.Hope that helps. Any other specific questions, I'll try to answer if I think I might contribute something to the discussion.Wilson
Okay, where are you guys? I'd like to come listen too if you wouldn't mind.
I'm in ,let me know when .my home theater is complete lapsan
You still planning on coming by this Saturday for me to fix the cable?T
