Time for the sale of all sales. The deal of all deals!
0 Members and 1 Guest are viewing this topic. Read 110283 times.
djslash
Re: Time for the sale of all sales. The deal of all deals!
« Reply #120 on: 26 Nov 2013, 01:55 am »
The last deal was amazing so I am really ashamed to ask, what is the new one?
Also I need to know the X-Voce package size in order to calculate shipping.
Danny Richie
« Reply #121 on: 26 Nov 2013, 02:22 am »
I'll get all of that ready tomorrow.
skalos
« Reply #123 on: 14 Apr 2014, 10:03 pm »
So Danny,
If I had enough woodworking skills to remove the "bottom" of the x-voce between the sealed woofers and supported the structure properly in another way (similar to your photo of the OB-5 at the back of the speaker), can I turn the x-voce upright and use it as a large monitor with open baffle for the center section (MTM)?
Steven
Danny Richie
« Reply #124 on: 14 Apr 2014, 10:14 pm »
So Danny,
Steven
The crossover was designed with the bottom between the two mids in place. Removing it would require the crossover to be altered.
You might be surprised at how good they sound as is and stood up on its end. It would need a pretty beefy stand though.
dingus
« Reply #125 on: 12 May 2014, 04:17 am »
how do i go about getting one of those X-Voce center speakers?
Danny Richie
« Reply #126 on: 12 May 2014, 04:21 am »
Just call to order: 940-592-3400
dingus
« Reply #127 on: 12 May 2014, 04:25 am »
thanks Danny!
nevermind the PM's, i'll call tomorrow.
dingus
« Reply #128 on: 20 May 2014, 12:12 am »
a quick follow up...
i ordered an X-Voce in black and received it the other day.  just put up a wall shelf for it, hooked everything up and plugged in the parameters for the new center, and the system sounds just glorious.  also, i was able to finagle an x-over upgrade that is on its way.
thanks Danny, i figure i owe you at least $20 on this deal.
Danny Richie
« Reply #129 on: 20 May 2014, 12:29 am »
No worries. Maybe you'll want to order something else from me one of these days.
dingus
« Reply #130 on: 20 May 2014, 03:32 am »
yeah, i'd thought of that too!
dingus
« Reply #131 on: 28 Jun 2014, 01:45 am »
quick update:
its been about a month since my X-Voce had the upgraded xo installed, and all the eq has been dialed in.  i was really worried about the integration with my main speakers, but i am quite happy with the end result.  it makes for a really nice addition to my system.
skeeter99
« Reply #132 on: 12 Mar 2016, 12:19 am »
Danny, are there any X-Voce or X-Statik's still available?
Danny Richie
« Reply #133 on: 12 Mar 2016, 12:45 am »
As for completed speakers, I do have X-Voce models in stock. No more X-Statik's though. They are only available as kits.
skeeter99
« Reply #134 on: 12 Mar 2016, 12:49 am »
Got it, thanks! Kicking around a number of ideas here :) Getting ready to take the plunge!
mlundy57
« Reply #135 on: 13 Mar 2016, 10:18 pm »
Danny,
Do you have the plans for the X-Voce anywhere?
Would this work with the X-Otica as well as the X-Static or would it need to use the M165NQ's to match well with the X-Otica?
Mike
Danny Richie
« Reply #136 on: 14 Mar 2016, 12:16 am »
Danny,
Mike
I can e-mail you the plans.
It would match pretty well with the X-Otica too.
mlundy57
« Reply #137 on: 14 Mar 2016, 02:00 am »
