On the PS. I read here and there that some used 18V regulators in place of the 15V.
IMHO, I'd not recommend 18V.
0.01uF 50v pp Cap
"slightly" oversized, but still good:
P14255-ND
P12109-ND
0.22 uF 50v pp Cap (I've found a 250V version, PF2224. Will this work?)
The size is the problem here too:
BC2062-ND
P12107-ND
The PF2224 may be OK, but the caps are used in the equalization circuit and better be more precise than 5%.
For me, the choice on the Digikey is limited, so the suggested substitutions are not the best for the circuit.
I've found all part except the 15V positive regulator, PN# NJM#78M15fA.
There are plenty of them:
Digikey->Product Index->PMIC - Voltage Regulators - Linear (33,900 items) ->Voltage-Output = 15V (Apply Filters)->Package Case= All varieties beginning from TO-220 (Apply Filters)-> Mounting Type = Through Hole -> In Stock (check!) (Apply Filters).
For example - NJM7815FA#-ND
