Liebert UPS for amplifiers
0 Members and 1 Guest are viewing this topic. Read 2551 times.
wilsynet
« on: 16 Dec 2010, 10:07 pm »
About a year ago I moved into a new place and the voltage was very low and there wasn't much I could do about it.  I remembered reading a thread on Audio Circle and I ended up purchasing a Liebert GXT2 1500 VA UPS.
This was the thread:
http://www.audiocircle.com/index.php?topic=70904.20
When I recently commented on this thread:
http://www.audiocircle.com/index.php?topic=87121.0
More than one person commented that the Liebert is really a step backwards.
Any more thoughts on the Liebert, is there a new consensus opinion?
mjosef
Re: Liebert UPS for amplifiers
« Reply #1 on: 16 Dec 2010, 10:54 pm »
Ummm...was it? I mean for you?
JDUBS
« Reply #2 on: 17 Dec 2010, 12:15 am »
I'm curious about this too, as I've never heard it and it definitely isn't the case for me.
-Jim
fly_fish_nz
« Reply #3 on: 17 Dec 2010, 01:21 am »
I purchased the same unit and found it a welcome step forward.  My next step is to replace the fan (or is it fans in this unit?).  Very happy with my purchase and the results.
shadowlight
« Reply #4 on: 17 Dec 2010, 01:44 am »
Personally I found the sound to improve but the fan noise turned into distraction.  Once I figure out how to reduce the fan noise and hide the Liebert it is going back in.  I will have to plug it in at the next RAVE.
JDUBS
« Reply #5 on: 17 Dec 2010, 03:01 am »
Guys, you need to definitely replace the fan(s).  Super easy and makes them practically silent.
Recommended fans are in the original Liebert thread.
-Jim
shadowlight
« Reply #6 on: 17 Dec 2010, 03:30 am »
-Jim
Thanks Jim.  Will read through the thread to find the location and time of fans.
JDUBS
wilsynet
« Reply #8 on: 17 Dec 2010, 07:32 pm »
I prefer not to call my landlord, call the utility company, etc. if it can be helped.  I don't quite have the capacity to take on another project, even if it means that other people do the work and not me.
Do I notice a step back sonically?  No.  But I'm comparing against the very sub-optimal wall power -- and the voltage from the wall is all over the place.  I don't have power available to the house which would act as a reasonable base line for comparison.
wilsynet
« Reply #9 on: 17 Dec 2010, 07:37 pm »
There were 2 fans to be replaced in mine, and rather than use solder or a wire wrap, I purchased 2 pin to 3 pin converters.  Couldn't figure out what type I needed (they are not interoperable), so I just ordered all 4 of them.
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=34_289&zenid=9d5103d0362304e60a1f74130717d3ae
There are styles A, B, C, and D.  They're 99 cents each, and they came unlabeled, so I still don't know which type is the appropriate one.  A bit of a waste, but a waste that cost me $8, so not a big deal.
