0 Members and 1 Guest are viewing this topic. Read 27740 times.
I know, but doesn't it seem especially volatile right now?
I am going to concentrate on digital source this year at RMAF. What digital sources are at the show and what would y'all recommend as must hear. I am going to carry a flash drive with hiRez songs that I am familiar with.
You MUST hear the Bryston BDP-1, and then find the other minimalist Linux front ends (Auraliti, Sonore, etc) too. My days at home with the BDP-1 were quite good!!
It can play around, with DACs that offer BNC/coax or AES inputs.
EAR Acute 3The Acute 3 is Tim de Paravicini's latest CD player. The original Acute employed the excellent Wolfson, 24/96 upsampling DAC. The Acute 3 employs the latest Wolfson DAC, which upsamples to 24/192. The Acute 3 also offers digital inputs—S/PDIF, Toslink, and USB. Everything beyond the DAC is of Tim de Paravicini's design, including the filters and the output stage. One thing that makes the player unusual is the fact that the filters are analog, not digital. Another is the transformer-coupled tube output stage. A third is the fact that it has enough gain to drive a power amplifier directly, with the front-panel volume control (also analog). The Acute 3 CD player offers both true balanced and single-ended analog outputs. Review link: http://www.positive-feedback.com/Issue54/ear_acute.htm
What DAC(s) were you using with the BDP-1 with?
Is BDP-1 married (monogamous) to BDA-1 or can it play around?
http://www.audiocircle.com/index.php?topic=97925.20
I recently bought an E.A.R. Acute III CD player/dac.I been quite happy with it. I've been using it primarily as a cd player, but last week I hooked it up to a Mac G5 running Pure Music for both 24/192 spdif and (no needed driver) usb. In this last month I've had one of those - ya don't know how good something can be until you hear it set up mo' betta. Heretofore, I've believed that current production tubes were perfectly adequate.... What a mook. So I first replaced the 2 supplied PCC88s with a multitude of tubes, both 6dj8/ECC88 and7dj8/PCC88. IMO, the design is wonderful in that both 6,3 and the far less expensive 7.2 volt filament tubes may be used as the filaments are powered via a constant current source. Each tube serves both channels, the first, filtering and the second buffering, allowing the choice of tubes specific for its function. I ended up with a Siemens PCC88 in that first position, and a Dutch Amperex in the second. Actually I ended up with 4 of each, my lifetime supply, and they were the far less dear PCC88 rather that costly ECC88/6dj8, at the whopping cost of $40 and $15 each. Ever price a NOS Siemans ECC88/6dj8?While the tube complement I prefer may not be another's preference, the Acute's tube implementation affords its owner the ability to customize the sound to their specific preferences.I've heard the Lindemann and Playback Design CD players. I've also heard the dcs and EMM stacks. IMO, the Acute III, properly tubed, plays in their sandbox. I believe I prefer the sound of the Acute, but I've not heard those players and dacs in my own system.FWIW,PaulEDIT: Dan Meinwald of EAR, along with one of his dealers, will have the Acute III in Room 1104 at RMAF '11. Dan's rooms are always a joy to listen to.
Are you talking stock or did you tinker with it?
The "acute III" can accept up to 24/192 digital input from USB, coaxial SPDIF and Toslink SPDIF devices. Immediately upon returning to the analog domain, the audio signal is passed to analog filters of Tim de Paravicini's own design. The audio is output from a transformer-coupled PCC88tube line output stage as in EAR pro audio equipment. This allows true floating balanced output as well as identical quality unbalanced line out by RCA connectors. The maximum output is 5 volt, which means it can drive directly any power amplifier of any type, with analog volume control that can be controlled by remote handset.
I am woefully out of date on digital playback as I have been spinning vinyl for the most part. Since Ted is up on all the latest developments on DACs, I will ask the question here even though my question pertains to Redbook playback as well. Starting from scratch with an arbitrary budget of $10K, how does one construct a digital front end that will give the most bang for the buck? It will just be the front end consisting of a transport, a DAC and whatever else that is needed to play digitized music both on discs and in stored files. Let's assume there is already a server with stored music files in FLAC and WAV but discs must also be able to be played directly.
