0 Members and 1 Guest are viewing this topic. Read 27765 times.
Where did you read that?
...I think the issue here is that this is not a product designed for thousands of music files and the management of such. it is really much more applicable to someone wanting to listen to and have access to hundreds of files rather than thousands....
No the BDP-1 can play any number of songs. It just takes longer to load a T-BIT drive over say a 16-G thumb drive which takes a few seconds. Once the USB drive is loaded it stays loaded and you can access the song lists very quickly through whatever interface your using - mPod, iPad, iTouch, iPhone your computer, minion etc. or Bryston web interface.I realize some people want to play with thousands of files at a time but I think most will use the BDP-1 as I do. For instance I have a 500G USB hardrive connected to the back of the BDP-1 and it has about 5000 songs on it. Then I have about 10 Thumbdrives with different material - a Jazz one, a Classical one, a top 25 favorites etc. which I use from night to night depending on my mood.One of the things I have noticed since I have been using the BDP-1 is I tend to use it more like a large CD player rather than a server.
I would say about 10 minutes with 1TB - but once scanned the access to the material is very quick. But as I have said before I do not think the BDP-1 is for those folks wanting to deal with thousands of songs. It is really geared more to someone wanting to managing and listen to hundreds of songs with the highest quality possible.
http://www.audiocircle.com/index.php?topic=82098.msg816697#msg816697 http://www.audiocircle.com/index.php?topic=82098.msg847142#msg847142 http://www.audiocircle.com/index.php?topic=82098.msg846715#msg846715 Steve
SRB - where do you go for this SSD mod on the Mac Mini: info & retailer?
Can you use the remote app through the itunes to run the Pure Music? That is how I control my Mac Mini. Thanks,Morgan
Anyone try the PS Audio perfectwave dac and bridge?
Don't forget the Wadia 521 dac. I have one and although it's limited to 24/96 the sound is very natural and it has an excellent digital volume control built in. For reasons I don't understand this dac is rarely mentioned in articles and reviews which in my view is unfortunate.
What server, Woodsyi? it makes a difference, cuz if it's a MAC, then a direct connection (firewire preferably, or asynch USB) DAC is in order. If it is a pc then you might need an S/PDIF to USB interface before the DAC (budget $1k max). A newly discussed Linux-based server, Auralitii, is $799 and S/PDIF based. Some say it is the quietest most musical out there. More to come...Off the top of my head stuff.......Great DACs I've heard that play redbook to 24/192:primary connection is firewire:Metric Halo LIO-8 $3400 (also is an 8 ch DAC if needed, MAC -based software, can be driven directly to some amps) Weiss DAC202 $6k (can be a digital preamp as well)Prism Orpheus ($4k) (also an 8 channel DAC, can be driven directly to some amp)Weiss DAC2 ($2300 used...mine ) primary connection is asynch USB: Antelope Zodiac Plus ($2500)Ayre QB-9 ($2600) USB onlyWavelength Coscecant ($3500-6k depending on options) (tubed)Wyred4Sound DAC2 ($2k) (Can be driven directly to some amps, includes HT bypass)primary connection is S/PDIF and/or AES/EBU (i.e USB is not 24/192 or USB is not good aysnch interface):Forsell MDAC-2 ($3k)Eastern Electric Mini Boulder modded ($1500+ depending on mod) (tubed)Berkeley Alpha ($5k) (can be digital preamp)I'll add more. Several of these DACs sound only average until about 400 hours. A real PITA when eval'ing them. I've not heard some of the other contenders: the PS Audio PWD/PWT, Audio-GD ref 7, Cantata or Wavelength Crimson...
Software game just changed a bit today, with Pure Music supporting FLAC now. Will save me a lot of hassle coverting files from FLAC. Nice program, with some great features and capabilities. And uses iTunes interface though bypassing its effects on sound.
Where did you see that PM supports (or will be supporting) FLAC?
PM 1.7 is out now and includes FLAC capability.
