0 Members and 1 Guest are viewing this topic. Read 2358 times.
2) When used with the power suppy module built to standard spec (+-15vdc), the voltages on the opamp supply pins should be +-15 vdc, correct?
3) ...can i simply substitute the voltage regulators with 79m12 / 78m12 and leave all other resistors, capacitor and transformer parts as listed in both the power supply and the bugle?
5) Are C7 and C10 on the Bugle card still needed when used with the power supply?
My effective voltages out are -12.02 and +11.81, so pretty close.
One question I have - R4 and R7 run hot, too hot to keep a finger on them for more than a moment or two. Is this normal? Should I go to two watt resistors here?
Wait a second! You are dropping the DC output voltage from 15V to 12V DC, but you increased the transformer AC voltage from 15v to 18V AC. That doesn't compute.
