Oldest piece of audio gear you currently use
0 Members and 1 Guest are viewing this topic. Read 26755 times.
cheap-Jack
Re: Oldest piece of audio gear you currently use
« Reply #160 on: 16 Nov 2011, 06:15 pm »
Hi.
My Dynaco ST70 is oldest.
James
Bingo, James. I am using the same one matting with PAS-2. Both 50 years old, still kicking around like kids.
I super-restored both of them in my own most cost-effective way, WITHOUT need to purchase any new driver boards from vendors like most many upgrades out there. Now they both sing like a nightingale.
I'm a vinyl die-hard, my TT is also 40 years old vintage Thorens 125II. It plays my many hundreds of vinyls, recyled & brandnew like magic. I put it on my custom-built 100lb-heavy platform made of 2 hollow concrete blocks.
My loudspeakers are also vintage 40-year KEF 2-way bookshelvers mounted on steel stripods. I virutally rebuilt them to deliver superior sound from Pavarotti to Tom Jones.
Very old gears indeed. Yet the sound is not vintage at all - 3-D virtual soundstage, see-thru transparency, fast, dynamic & musical.
This old vintage system beats many modern tube gears, brandnames or home-brews.
c-J
"If the facts don't fit the theory, change the facts." quoted Albert Einstein.
rajesh
« Reply #161 on: 18 Nov 2011, 07:39 am »
I have two vintage amps:
1. Luxman L-80V
2. Technics SU8022
Technics is good but Luxman is awesome.
Johnny2Bad
« Reply #162 on: 18 Nov 2011, 11:35 am »
MacIntosh MR-74 (AM/FM Tuner)
drjjpdc
  • Guest
« Reply #163 on: 16 Dec 2011, 02:51 am »
Well I just acquired an old AR TT in good shape (the plinth is original solid walnut), but since it is not in use yet, I'll mention something else. I have a Kenwood Stone TT KD-500 from about 1985. The next oldest piece I own is a Pioneer PD-65 Elite CD Player (the Rosewood panels still look great).
closeyoreyesandlisten
« Reply #164 on: 9 Jan 2012, 08:48 pm »
New to this Audio Circle site and having some fun within the "Circles":
Main System: CD or Tuner into:
Early 50's Stromberg-Carlson ASP-422 Power Amp (using attenuators for volume control - no preamp); sound comes out of a pair of University Master Series S6 Speakers (3 way) in origional 1956 (or so) cabinets... Sweet!
medium jim
« Reply #165 on: 9 Mar 2012, 02:54 am »
A 1962 (thought it was from 1961) McIntosh MX-110 pre/tuner.  Was serviced and tweaked about 4 years ago.
AgentOrange
« Reply #166 on: 9 Mar 2012, 03:42 am »
Great McIntosh MX-110.  In 1962, you could buy tubes at the drug store or the filling station (gas place).  All had tube testers and a supply.
Most of my junk is old (some say vintage).
At the end of the day, if it sounded good in '62, it can today.
AgentOrange
« Reply #167 on: 9 Mar 2012, 03:47 am »
Around 1960 I rebuilt a Stromberg-Carlson radio.  That meant I sanded it down and put on new varnish and put in new tubes.  I was a proud boy!
medium jim
« Reply #168 on: 9 Mar 2012, 03:49 am »
Thanks, it sounds pretty darn good to my tin ears 8)
Jim
Meicheng
« Reply #169 on: 9 Mar 2012, 03:52 am »
In my case its my KLH Model 100 AM/FM Clock Radio.  25 years old and still works perfect.  Wakes me up every morning.  Pretty good sound for a clock radio.  It was pretty expensive when I bought it, at $150, but I've certainly got my monies-worth and am darn glad I purchased it.
dingus
« Reply #170 on: 9 Mar 2012, 10:41 pm »
Large Advent Utility
Hafler DH-101
Yamaha CR-2020
only the Yamaha is not currently being put to use, but its only an issue with dirty controls.  if i find a good spot for it, i'll fire it back up.
TheChairGuy
« Reply #171 on: 10 Mar 2012, 01:53 am »
If it weren't for my 1960 era Dukane tube monoblocks...the oldest 'gear' would be my 1963 era ears  :wink:
Austin08
« Reply #172 on: 10 Mar 2012, 07:01 am »
1. Luxman L-80V
2. Technics SU8022
Me too, The Luxman still works beautifully in my home office.
doug s.
  • makin' music
« Reply #173 on: 10 Mar 2012, 07:15 am »
i may have mentioned before; here's some of the mainstays in my system:
- vmps larger subs - ~17yrs
- electrocompaniet aw75dmb's, driving the vmps' - ~20 yrs
- melos ma333r preamp - ~20 yrs
- oracle delphi turntable - ~32 yrs
- dbx 3bx dynamic range expnader - ~35 yrs
regarding other equipment, present tuna - rotel rht10 - is 19yrs.  other tuna in rotation wary from ~14 years old to ~50 years old.  dac is ancient, relatively - modded art di/o, ~12 years old.  amps (tube) range from ~5yrs to ~50 yrs, depending on what's in rotation.  also getting use are relatively modern gainclone and ucd180 s/s amps.
doug s.
Satxhifi
« Reply #174 on: 10 Mar 2012, 09:14 pm »
 2 Scott 350B & 1 Scott 350 tuners. '61 & '62
Scott 299 & Scott 299B. 1959 & 1960
AR7 bookshelves, 1973
Best,
Dave
medium jim
« Reply #175 on: 11 Mar 2012, 03:43 am »
Marantz Model 9 VAC Reissue Monoblocks  1997
McIntosh MX-110 Preamp/Tuner 1962
Marantz CDP 38 modded by Ah Troeb 1999
Magnepan MG 2.5RT Speakers 1987
Bower&Wilkens ASW300 Subwoofers ca 2007
There is magical synergy going on with this system.
eleet
« Reply #176 on: 27 Mar 2012, 05:05 am »
Marantz HD-77 speakers (1976) with original sculpted foam grills - designed by Ed May.  Still sound great with bottom end that really hits you in the chest.  Had the woofers re-done by Bill Watkins just before he retired.  In the the process of upgrading the crossovers.  Also have a Thorens TD160-C turntable (1976) which I mounted a Grace 707 MKII tonearm on in 1979.
Subhunter
« Reply #177 on: 31 Mar 2012, 01:04 am »
Nakamichi OMS 1A  CD player. I must have picked it up
back around 1988
michaelhigh
« Reply #178 on: 11 Apr 2012, 01:33 am »
Beautiful AR4X's from vinyldavid, AR-XA (nearly mint) from CL score ($100). :green:
knabelmarc
« Reply #179 on: 16 Apr 2012, 04:55 pm »
Threshold S500 Stasis Linear Stage Power Amp
