0 Members and 1 Guest are viewing this topic. Read 15645 times.
Vertical is 1 stereo amp per speaker, horizontal is 1 stereo amp for bass and 1 stereo amp for mids and highs.Lin
Freo-1,What are you using for an active crossover?
Good Stuff. Now see if anyone can answer this. I have a pair of Plinius SA100's that can be used as stereo 100w/ch or mono at 400w/ch. I am using the mono switch wich produces more power and each mono is running a B&W 802D. However, the way Plinius works in mono mode, the user can only use the positive outputs. So i am not even sure if you could biwire if all you have are the positive posts. Do you still think Vertical bi amp is better when you lose the 400w but you can biwire to the speakers? Thanks
How is vertical bi-amping different from using a single stereo amp with the corresponding watts per channel? I understand that in the latter case both channels share the same power supply, but if it's properly designed that shouldn't matter. (And don't some amps have separate power supplies for the two channels?)
Can passive vertical bi-amping be done with an multi channel AV receiver? Say 5.1 receiver. Fronts for one speaker, rears for the other.
