FS: Emerald XL's in Piano Black
0 Members and 1 Guest are viewing this topic. Read 1610 times.
Affordable$$Audio
« on: 30 Sep 2010, 05:11 pm »
Here is your chance to pick up a pair of terrific ACI Emerald XL mini-monitors in the high gloss piano black $400+shipping. As much as I’ve enjoyed my 18 months with them, they deserve to be heard every day (forgive me Mike!). Top to bottom coherence is outstanding, the top and midrange is wide open and downright magical at $800 new. Both my review and Jeff Dorgay’s in TONEAudio match up with what customers experienced. The speakers are an easy 9/10 on the Audiogon scale and come in their original double box. Shipping measurements are 18x16x13, weight 27 lbs. Shipping from 97116. Please PM with questions. Payment via Paypal.
Below are photos and specifications:
Frequency Response 70-20khz +3db
Nominal Impedance: 8 ohms, minimum impedance 7 ohms, low reactance
Sensitivity: 86db 1 watt/1 meter
Dimensions: 10" H x 5 7/8" W x
8 1/4" D
Weight: 11 lbs each
Tweeter: 1" silk dome with ferro-fluid and aperiodic second chamber
Bass-Midrange: 4" cast-frame with paper cone, rubber surround; long throw, low distortion motor system with vented pole piece
Recommended
RMS Power: 20 to 150 watts per channel
Bass-Loading: Fourth order, low Q, rear ported system. May also be used as second order sealed system.
Cabinet: Full 3/4"" MDF with extensive interlocking bracing structure.
Affordable$$Audio
Re: FS: Emerald XL's in Piano Black
« Reply #1 on: 4 Oct 2010, 04:57 pm »
SOLD
