0 Members and 1 Guest are viewing this topic. Read 2420 times.
Recently, I had a customer write about some confusing speaker reviews (about the same speaker). Wattage reported for good results ranged from 30 watts to 150 watts per channel. The question: How could such a range sound good? My answer:I own a pair of Von Schweikert VR-2 speakers. They are in theneighborhood of 86db efficient- which is very low. A five wattamplifier will drive them and actually do very well with several kindsof music. Many people will ask why others want more wattage.The limitations of 5 watts on these speakers:1. Dynamic range reproduction: There is no room for transients orcomplex passages2. Severely limited volume: The speakers can be driven to just belowthe optimum levelThe optimum wattage for these speakers is 80 to 100 watts. One of myhigh end receivers has a peak reading watt meter. While playing musicat moderate impact levels, I get spikes of up to 40 watts whilelistening with an average wattage of 8-10 watts. A high impactlistening session will easily absorb 80 watts when the average poweroutput is only 20 watts.Chamber music can be played and sound very good on the VR-2's with afew watts. However, when Bluegrass, 80's, movies, etc.. are beingplayed, it is advisable to use considerably more wattage.It boils down to what an individual listens to and how they want tohear it. Wattage can have a direct impact on sound quality, as statedabove.
Few people seem to understand that any given speaker has a limit in terms of how much sound pressure it can generate - regardless of how many watts you put into it. So at some point every speaker begins to compress the dynamics. When you reach that point, you have enough power.
Since volume can be increased or decreased, instead of the need for all that power, what becomes more relevant is how much power you need at the volume you listen at with regards to your listening environment. I would call this a matter of ratios. Being able to produce accurate peaks is incredibly important. With low-watt playback, these peaks should be reproduced relative to the average power being produced. For example, my average listening wattage is 1-5 watts with 92db efficient speakers. Yet, I have noticed improvements going from a 5-10 watt amp to a 60-100 watt amp. The small amp did an admirable job- nearly perfect, but I noticed an increase in richness and accuracy of instrument placement (sound stage) with more power. I still very much like low power amps (5-10 watts) because they offer so much for their price and can come VERY close to their big brothers in performance. Not all low power amps are inexpensive- so it's wise not to spend allot of money when the physics of low wattage playback issues remain for any low-watt amp. You can spend ALLOT of money pushing the envelope of low-watt performance and many will be truer in sonics than high-watt models. I do not recommend this route. It is far better to invest in a larger design if it's necessary and make the larger amp perform at its best.
It is not necessary to use 100+ watts with 97db speakers, but it will work very well. I do it all the time. My Ashley FET 500 war horse works great on my 100db RF-83's as does my QSC USA-850. The QSC sounds much better to me, I admit. Both amps produce well over 100 watts/channel. I use my NS-60 in my Klipsch system frequently and find it extremely enjoyable. Due to the speaker's efficiency, I have not found any benefit in running over 60 watts per channel because the room is small. Moral of the story: Never say never.
